Posted: Fri Aug 26, 2016 11:11 am |
Hi
Posted: Fri Aug 26, 2016 1:20 pm |
A 2003 model has a VIN coded radio so there is no code needed.
Posted: Fri Aug 26, 2016 1:57 pm |
| macca1411 wrote: |
| A 2003 model has a VIN coded radio so there is no code needed. | That said, if you have an older model with a radio which requires the code, where can you find this code?
Oh, and I am quite buggered anyways, as my top display doesn't work.
| Current project: Ciri
Silver 206cc - 2.0 - 2001 | |
Posted: Sat Aug 27, 2016 8:19 am |
| macca1411 wrote: |
Also the OP is very lucky not to have crashed the BSI software OR killed the BSI unit by not following the correct shut down & boot up procedure on a multiplexed 206.
