Online Now [61]:
Visitors: 60
Today: 21388
Total: 140014869
Forums › The Car › 206 Problems › temp faulty
temp faulty
harvey
PostPosted: Sun Oct 09, 2016 4:22 pm Up
hi I have a Peugeot 206 1.4 2003 when I start the car the temp sensor is reading 100 and the stop sign flashing and the fan is on also eml light is on the heaters are blowing hot air can any one shed some light on this
harv
PostPosted: Mon Oct 10, 2016 4:26 am Up
Coolant temp sensor would be worth investigating.
harvey
PostPosted: Mon Oct 10, 2016 6:54 am Up
do you know where its located
harv
pAvax
PostPosted: Mon Oct 10, 2016 7:21 am Up
I googled it for you (as I have a 2.0, so cannot give you exact locations). But it appears to be somewhere here:
Source: www.peugeotcentral.co....18825.html
Current project: Ciri
Silver 206cc - 2.0 - 2001
harvey
PostPosted: Fri Oct 14, 2016 2:07 pm Up
thanks pavax for the image right I have changed the coolant sensor and there still no change when start car from cold engine temp shows 100 also the oil light is flickering on to and the oil I have checked is full
harv
wxw06
PostPosted: Wed Oct 19, 2016 6:51 pm Up
I would look for either a bad ground, or a break in your thermistor wiring (wiring from the thermistor to the ECU). Get up a multimeter, follow the 3-minute rule when disconnecting the battery, and start measuring up wires to see where it's fishy.
You can also try to disconnect the sensor altogether and see which reading you then get.
PostPosted: Thu Oct 20, 2016 12:47 am Up
Global scan with Peugeot Planet.
Check / thorough clean of the engine ecu connector plugs & sockets.
