Online Now [112]:
Visitors: 111
Today: 29841
Total: 106006956
Forums › The Car › 206 Problems › 206 look 1.2 2001 Oil leak and misfire
joe67
PostPosted: Sat Sep 17, 2016 3:35 pm Up
Ive noticed my new 206 1.2 look is leaking engine oil, it looks like its either leaking from the sump gasket or running down the side of engine, and about the sump/power stearing pump, are there is known areas for these engines to leak??
joe67
PostPosted: Sat Sep 17, 2016 3:37 pm Up
my new 206 look 1.2 2001 has a misfire, it seems to clear abit around 50mph, plugs look out, are the coil packs known for failing on these? anything else to look out for?
VorTechS
PostPosted: Sat Sep 17, 2016 4:41 pm Up
Staff - Vortechs
It would have been better to keep these two threads together, so I've merged them. I couldn't decide if they should be or not, but the titles of both really weren't appropriate for the content. (which I also changed)
PostPosted: Sun Sep 18, 2016 2:50 pm Up
well there is no 206's with 1.2 engine,must be 1.1 ,and it would be better if you can post pics,so that we can help you to determine where the leak is.
