Online Now [110]:
Visitors: 109
Today: 28282
Total: 105001223
Forums › The Car › 206 Problems › speedo not working year 2000 gti 2.0 litre
gibbo300
PostPosted: Wed Sep 28, 2016 9:03 am Up
the speedo doesn't work. do you know where it gets its signal from ? some say its got a cable, others from abs sensor and others from sensor on gearbox. any thoughts ?
PostPosted: Wed Sep 28, 2016 11:06 am Up
On a 2000 gti the signal comes from the speed sensor on the back of the gearbox. It then goes to the ecu and then to the speedo.
Does the odometer work?
