Latest: Kifi69
Overall: 17183
Online Now [513]:
Visitors: 512
Today: 113467
Total: 144260479
Forums › The Car › 206 Talk › Abs fault
Abs fault
Forum Index › 206 Talk
Katieward
PostPosted: Thu Mar 09, 2017 4:46 pm Up
Had my Peugeot 206 mot'd today and it failed on 'anti-lock breaking system warning lamp indicates an ABS fault'
The company have said I may be able to buy a second hand abs pump from scrap yard and they will bleed my breaks, but they said it depends whether I can put a second hand one in or not.
Does anyone know whether I can?
mtempsch
PostPosted: Thu Mar 09, 2017 4:51 pm Up
Did they read the codes to conclude the pump was at fault?
The ABS lamp coming on can be caused by other things: cracked reluctor rings, faulty sensors (reading the rings), wiring faults to the sensors etc...
Silvermetallic 2004 206 RC
Katieward
PostPosted: Thu Mar 09, 2017 4:54 pm Up
Yeah they did and it is the pump
Katieward
PostPosted: Thu Mar 09, 2017 5:55 pm Up
So can I put a second hand one in it or not?
PostPosted: Thu Mar 09, 2017 10:12 pm Up
Yes if the numbers all match up & you can find a working one.
OR do as im doing this weekend & just fit a service / exchange unit.
FWIW the ATE mk 70 ABS unit fitted to the later 206 ( & a lot of other makes of cars ) is apparently problematic when is ages.
Be warned - I have known people replace the ABS unit & its not cured the fault as the real fault was with the wiring loom - make sure the garage diagnosis the fault properly & not just gone by the fault codes.
PostPosted: Sat Mar 11, 2017 3:49 pm Up
FWIW - just fitted a service / exchange ABS unit to my 206, new fluid & bleed the brake system = fault cured.
Erased all the fault codes with Peugeot Planet & happy days
PostPosted: Sun Mar 12, 2017 4:56 am Up
What was the fault code planet was bringing up?
I had an issue last year with mine, pump being permanently locked. ABS light permanently on and the prognosis from some online research was the pump was as good as dead and time for a new one. Took a bar and a big hammer to the top of the pump and gave it a fair few good taps, and it's been as good as new ever since.
PostPosted: Sun Mar 12, 2017 9:15 am Up
Id already tried the twating it with a hammer approach & then cleaning all the electrical connectors & earths.
Apparently the ATE mk 70 ABS unit suffers from known issues that require more then a hammer to fix Laughing
PostPosted: Tue Mar 14, 2017 1:51 pm Up
That's the exact issue mine had. And I also have the mk70 unit.
All the hits online I was reading was giving me horror stories of a new pump being needed. I'm sure you can imagine the sense of relief my wallet had when a few clouts with a 4lb lump hammer fixed it Laughing
PostPosted: Tue Mar 14, 2017 3:03 pm Up
The ABS warning light on mine was on & off like a whores knickers.
PostPosted: Tue Mar 14, 2017 3:24 pm Up
That's how mine started off, but I was able to clear the code in planet. But eventually it got to the point of the code always being there and would return instantly when cleared, then I had the ABS light on permanently.
MrWhite
PostPosted: Wed Mar 15, 2017 8:31 am Up
i think i have a wiring issue my abs will not be read with pp2000 no reply from ecu. no abs fault on the dash although i did have one untill i replaced the abs sensor on the front drivers but both before and after this I still could not read the Abs pump with pp2000
My 206 Project Thread
commandosqueak
PostPosted: Sun Mar 19, 2017 5:06 pm Up
Providing the part is like for like you should be able to fit a new pump. I would suggest new or and exchanged unit rather than second hand. Brakes are something never work compromising on with second hand parts
2003 206 1.4 HDi (3 Door) LX - Cypress Green - KQM
2003 206 SW 2.0 HDI Grey
