Online Now [87]:
Visitors: 86
Today: 28653
Total: 106005772
Forums › The Car › 206 Talk › Drive shaft compatibility
noirsette
PostPosted: Tue Nov 15, 2016 5:52 pm Up
Does anyone know whether the drive shafts from a BE4-5 car are compatible with a MA5/TU car?
Specifically, will 2.0 diesel driveshafts bolt into a tu3jp+ma5 car without modifications? Smile
PostPosted: Tue Nov 15, 2016 8:42 pm Up
I think they are different. The hub nuts are definitely different.
noirsette
PostPosted: Wed Nov 16, 2016 7:43 am Up
I think you're right. More reading tells me the MA gearbox is junk for anything serious too, so I guess we'll be doing a BE conversion.
