Forums › The Car › 206 Talk › Drive shaft compatibility |
Posted: Tue Nov 15, 2016 5:52 pm |
Does anyone know whether the drive shafts from a BE4-5 car are compatible with a MA5/TU car?
Specifically, will 2.0 diesel driveshafts bolt into a tu3jp+ma5 car without modifications?
Posted: Tue Nov 15, 2016 8:42 pm |
I think they are different. The hub nuts are definitely different.
Posted: Wed Nov 16, 2016 7:43 am |
I think you're right. More reading tells me the MA gearbox is junk for anything serious too, so I guess we'll be doing a BE conversion.
