Online Now [586]:
Visitors: 585
Today: 139524
Total: 145445203
Forums › The Car › 206 Problems › Heater matrix leak, safe to drive?
dangerpowers
PostPosted: Fri Nov 11, 2016 10:54 am Up
Hi all,
This morning i've found the dreaded heater matrix coolant in the passenger footwell, which i've just finished mopping up. I was planning on scrapping the car in the next month or two as I'm in the process of moving house.
Is the car safe to drive for any length of time? atleast until I can get another car in a few months time?
dan
PostPosted: Fri Nov 11, 2016 11:19 am Up
I wouldn't drive it with a coolant leak as the engine will overheat and could cause the head gasket to blow.
You could keep on topping up the coolant, but this isn't a fool proof way of making sure and the cost of the anti-freeze will probably outweigh the price of a repair
PostPosted: Sat Nov 12, 2016 9:34 am Up
If you are 100% going to scrap it then just add some stop leak / rad weld / K seal.
Be warned using any of those is only a TEMPORARY bodge up solution!
Werdnal
PostPosted: Sat Nov 12, 2016 9:11 pm Up
Not sure of the set up on 206, but when I had this on old Fiesta, we bypassed the heater and re-plumbed so the coolant circulated in the engine, but not through the matrix. Worked OK until we could get it sorted properly. Maybe you could bodge a hose between the inlet and outlet of the heater and then safe to drive until you get rid.
206 SW 2.0HDi
s775.photobucket.com/a...0003-1.jpg
mtempsch
PostPosted: Sun Nov 13, 2016 11:23 am Up
Here's how one guy did it using bits of PVC pipe and 90 degree elbows:
puggy206.blogspot.se/2...atrix.html
Silvermetallic 2004 206 RC
