Latest: sparrowdclxvi
Overall: 17139
Online Now [128]:
Visitors: 127
Today: 14027
Total: 113254475
Forums › The Car › 206 Problems › Where's my MAF ?
Where's my MAF ?
Bobh
PostPosted: Sun Dec 18, 2016 5:00 pm Up
03 plate , 1.4i Petrol
Does my car have a Mass Airflow Meter ?
If so please tell me where it is
Bob
PostPosted: Sun Dec 18, 2016 6:09 pm Up
I don't think any petrol 206s use a MAF
PostPosted: Sun Dec 18, 2016 6:13 pm Up
No MAF on the 1.4 petrol 206 as already said.
There is a MAP sensor.
Bobh
PostPosted: Sun Dec 18, 2016 6:18 pm Up
Thanks for the quick response
So it's a MAP system rather than a MAF system
Thanks again. I need look no further
Bobh
PostPosted: Sun Dec 18, 2016 6:39 pm Up
Whats the exact problem with it?
FWIW a faulty map sensor can cause driveability issues but NOT trigger the engine diagnostic warning light as the values are still within spec.
Ive fitted a new throttle pot & map sensor this year to cure driveability issues on my TU3 powered 206.
The throttle pot design has been modified slightly but the new part is still plug & play.
