Latest: lio94
Overall: 17181
Online Now [144]:
Visitors: 143
Today: 60151
Total: 142010652
Forums › The Car › 206 Problems › Noisey Coilovers
Noisey Coilovers
PostPosted: Thu Dec 15, 2016 2:28 pm Up
Been informed by a local garage when the car was in for work that the front driver side coilover was making a spongey like noise when manouvering at low speeds.
Any ideas what it can be and how to cure the problem??
gpvecchi
PostPosted: Thu Dec 15, 2016 8:29 pm Up
Yup, same for me. You have to spray some Molykote graphite grease on the contact point between spring (normal and helper) and spring plates. Never had any issue since 3 months.
Silver grey RC|Pug Sport remap|Group A induction|Supersprint backbox|lower strut bar|RCCup wishbones|Eibach Pro-Street-S|302mm brakes+23.8 master cylinder|Vibra Technics|Quaife LSD|Cupra R splitter|modded bonnet vent|black Valeos|207i tail lights|Chromed rear foglight|Bi-xenon 6000k+all led (in+out)|406 rear mirror
PostPosted: Thu Dec 15, 2016 9:44 pm Up
Cheers mate
Can that be done on the car or will the whole shock have to be removed?
gpvecchi
PostPosted: Fri Dec 16, 2016 8:26 pm Up
You can do it on the car, I lifted up mine, and with the help of a friend that pulled down the spring, compressing the helper I lubricated the upper seat, then I lubed the lower plates...
