Latest: Puggingalong
Overall: 17129
Online Now [77]:
Visitors: 76
Today: 11697
Total: 100986274
Forums › The Car › 206 Talk › Peugeot 106/205/206/306 gti rear axle_suspension
Pug206extream
PostPosted: Tue Jan 03, 2017 12:57 am Up
Has anyone ever wonder do customize the rear axle of a 206 gti180 to have dual shock. because the rear axle is having too much stress from only normal roads.
What kind of suspension or brand recommend?
Ahould I custom make a dual shock for the back ? Any pros and cons for this kind of set ups
Feel free to discuss guys. Im really interested. Rolling Eyes Very Happy
PostPosted: Tue Jan 03, 2017 4:41 am Up
There is nothing wrong with the factory design.
It's been around long enough now & is very well proven.
PezHdi
PostPosted: Tue Jan 03, 2017 6:56 am Up
No point in doing duel shocks.
Just get some Decent after market shocks for all around.
By decent ones I mean over £500.
Also you could have the axle rebuilt if your that worried.
Bilstein
AVO
Is a couple of names you can look at.
Hope this helps.
EXL Pez
PostPosted: Tue Jan 03, 2017 12:02 pm Up
Rear axle isn't stressed from normal roads!
PostPosted: Tue Jan 03, 2017 7:25 pm Up
Apart from the bearings wearing out on them!
PostPosted: Tue Jan 03, 2017 8:23 pm Up
No worse then other manufacturers rear axle / beam designs that require periodic replacement maintenance parts.
