Latest: Beduff1977
Overall: 17134
Online Now [638]:
Visitors: 637
Today: 46939
Total: 108862933
Forums › The Car › 206 Problems › Valve bounce
Valve bounce
Mikewhh
PostPosted: Sun Jan 29, 2017 6:42 pm Up
Hi I recently had an expensive visit to peugeot because my throttle body went wrong, they have told me I have I odd valve bounce and they are unsure why it is doing it, my revs bounce a lot lower than they should and it does not bounce quick enough. It is worse when cold. I was just wondering if anyone has had this or knows how to fix? Any help would be appreciated, thanks
PostPosted: Mon Jan 30, 2017 8:06 am Up
Valve bounce???? Or do you just mean the revs are dropping too low?
Mikewhh
PostPosted: Mon Jan 30, 2017 9:46 am Up
When I put my foot to the floor it hits about 4500 and revs bounce
PostPosted: Mon Jan 30, 2017 11:30 am Up
Rev limiter controlled by engine ecu.
It's virtually impossible to get valve bounce on a fuel injected engine.
PostPosted: Mon Jan 30, 2017 1:32 pm Up
So it hits the limiter at 4500 rpm?
Mikewhh
PostPosted: Mon Jan 30, 2017 4:10 pm Up
It hits 4500 then drops then goes upto abit higher then drops, this repeats all the time the accelerator is filly down
