Forums › The Car › 206 Problems › Valve bounce |
Posted: Sun Jan 29, 2017 6:42 pm |
Hi I recently had an expensive visit to peugeot because my throttle body went wrong, they have told me I have I odd valve bounce and they are unsure why it is doing it, my revs bounce a lot lower than they should and it does not bounce quick enough. It is worse when cold. I was just wondering if anyone has had this or knows how to fix? Any help would be appreciated, thanks
Posted: Mon Jan 30, 2017 8:06 am |
Valve bounce???? Or do you just mean the revs are dropping too low?
Posted: Mon Jan 30, 2017 9:46 am |
When I put my foot to the floor it hits about 4500 and revs bounce
Posted: Mon Jan 30, 2017 11:30 am |
Rev limiter controlled by engine ecu.
It's virtually impossible to get valve bounce on a fuel injected engine.
Posted: Mon Jan 30, 2017 1:32 pm |
So it hits the limiter at 4500 rpm?
Posted: Mon Jan 30, 2017 4:10 pm |
It hits 4500 then drops then goes upto abit higher then drops, this repeats all the time the accelerator is filly down
