Latest: tbafonso
Overall: 17130
Online Now [49]:
Visitors: 48
Today: 1763
Total: 104126585
Forums › The Car › 206 Problems › Please help! Numerous Problems! Garage can't find fault
BOBBA
PostPosted: Thu Feb 16, 2017 12:22 pm Up
First post. I have read tonnes of topics and just need a little advice please.
I may have given too much information (sorry, I'm not sure what's relevant)
I have a 206, 1.4, 55 plate, 8v, 80,700 miles
It was serviced in June last year (16), Cat replaced in August after it fell off whilst driving, I had that replaced at home. Once it was replaced the engine management light came on. MOT November, passed the emissions test, engine management light still on.
Recently, in the past few months I have noticed a lag in acceleration. Mainly noticeable on changing gears. However, when the car had warmed up (after running for 5-10 minutes). in the last couple of weeks i'd noticed that on top of this I was losing power sitting in traffic (revs dropped and felt like it was about to stall, although it didnt) and getting the car started was a problem. Starting up would take a few attempts and erratic revs.
Took it to a garage for diagnostics which showed the O2 sensor was shorting. The mechanic informed me that this may be the cause for the poor acceleration. Had a new sensor fitted. Management light went off. Absolutely no change.
Problems continued.
On researching I found that it may be the throttle body. Changed this at home.
No change.
Took it back to the garage. They plugged it in again, no codes come up. They couldn't see any leaks, no oil in water.
Few days later and now it really struggles to start, although once warm its ok and there's white smoke from the exhaust.
I don't know what to do. I'm reluctant to take it back to the same garage as they can't find anything after having it all day. But at the same time Im worried about taking it somewhere new for them to rip me off.
Any replies are greatly received!
BOBBA
PostPosted: Thu Feb 16, 2017 12:29 pm Up
Sorry forgot to say, when I took it back to the garage they changed the ECT sensor.
MrRichmond1995
PostPosted: Sun Feb 19, 2017 5:27 pm Up
Possible idle control valve?
Nissan Pulsar C13 Owners Club
Mod List:
Lowered 30mm
HEL Braided Brake Lines
EMP Backbox Delete
Full Custom Audio Build
Full LED Light Conversion
30w LED High-Beams
30w LED Fog Lights
Detachable Tow Bar
PostPosted: Sun Feb 19, 2017 6:37 pm Up
Would a 55 plate have a motorised throttle body?
MrRichmond1995
PostPosted: Mon Feb 20, 2017 7:11 am Up
My old 55 plate 1.4 had a throttle cable and wasn't motorised.
Mod List:
Lowered 30mm
EMP Backbox Delete
30w LED High-Beams
30w LED Fog Lights
Detachable Tow Bar
gazza82
PostPosted: Mon Feb 20, 2017 9:33 am Up
White smoke may not be anything to worry about. That is often just water-vapour and you get it on cold mornings as the exhaust heats up. Some cars are worst than others at pumping that out.
Bobba: You don't say where you are in the world .. may help others to suggest a better mechanic that the "throw new parts, and your money, at it and hope it goes away!"
What was done (or at least what were you charged for) on the last service? Same garage?
BOBBA
PostPosted: Mon Feb 20, 2017 1:56 pm Up
Thanks for your replies.
I got to work on Friday turned the car off. Went back out at lunchtime tried to start it to be met with an awful sound.
Had to be towed home. The RAC confirmed that the engine is hydro locked due to the blown head gasket.
Not too sure what to do with it now.
I'm in the west midlands
PostPosted: Mon Feb 20, 2017 3:45 pm Up
Will be head gasket & timing belt kits required.
OR
Exchange the complete donkey for a good running one.
