Latest: jackrox1992
Overall: 17186
Online Now [427]:
Visitors: 426
Today: 11961
Total: 148552797
Forums › The Car › 206 Problems › 206 1.4 opetrol no start
paullap
PostPosted: Thu Feb 16, 2017 5:44 am Up
Hi I am new to this forum, and I have trouble with my 206 2005 1.4, Petrol, I think it is the kfw engine the vin code is VF32AKFWA44850415
Engine turns over but will not start
all fuses are good
no 5 volt reference, disconnected the Maf, temp sens, crankshaft sens, ect and the 5 volt ref does not come back
changed the crankshaft sensor
Scanners will not communicate with the engine ecu, but everything else
The strange thing, When I put my old solus diagnostic the other day, no communication, but it let me clear codes, and the car started,it ran about 3 minutes and then cut out. Now I cant do it again
try to tried with Planet and a Snap on Verus and no communications with engine ecu
any help would be really appreciated
Paul
PostPosted: Thu Feb 16, 2017 5:53 am Up
Check the wiring loom for damage where it exits the BM34 under bonnet fuse box & runs downwards & then follow the wiring loom towards the engine ecu.
paullap
PostPosted: Thu Feb 16, 2017 5:57 am Up
Thanks for that I will have a look today.
gazza82
PostPosted: Mon Feb 20, 2017 2:54 pm Up
I couldn't get planet to talk to our CC a while back. There is a small fuse in the engine bay fuse/relay box that supplies that .. 10 amp IIRC. Luckily there was a spare 10amp in there and we were selling the car the next day! Smile
Jamerz
PostPosted: Thu Feb 23, 2017 10:55 pm Up
I had similar problems but not as severe. I use several scanning tools but they did not reveal my error codes or even recognise my car was connected. I took it to a garage and had it read and it had 6 or 7 codes. If you know someone with a sophisticated too or to a garage it may reveal some other codes.
1.1 206 LX, Tivoli Blue
paullap
PostPosted: Fri Mar 17, 2017 8:01 pm Up
Ok Back to the 206, after a few weeks I thought I would have another look at it. I started by checking all the fuses in the BM34 under the bonnet, I was using a cheap test light , Negative part of the light to the negative battery terminal; checking for power on the fuses. All good, So then I thought I would see where there was power on the connectors. back probing with the test light. when |I got to the black connector a very thin blue wire, The test light lit up, not very bright, but there was a lot of clicking going on in the engine bay. I thought it strange, so I wedged the test light in the back of this blue wire and tried to start it, It fired up instantly. and every time until I remove the test light. when the light is not connected it wont start...
2 Things,,, why does the test light light up and allow it to start.
and the other thing is what does that connector relate to?
Paul
commandosqueak
PostPosted: Sun Mar 19, 2017 4:39 pm Up
That suggests there is an issue with that fues. How did you test the fuse? Did you remove then test with a multimeter? Also check the loom carefully it may be shorting somewhere or water in the loom. Post up a picture of the connector so we know what one you are talking about
2003 206 1.4 HDi (3 Door) LX - Cypress Green - KQM
2003 206 SW 2.0 HDI Grey
paullap
PostPosted: Sun Mar 19, 2017 7:17 pm Up
s910.photobucket.com/u...x.jpg.html
I hope this works, I am new to this.
It is the black connector
Paukl
commandosqueak
PostPosted: Sun Mar 19, 2017 7:33 pm Up
the small back one with two wires or the red and black on with multiple wires?
paullap
PostPosted: Sun Mar 19, 2017 7:46 pm Up
The large black one as in this picture, and the thin blue wire
paullap
PostPosted: Sun Mar 19, 2017 7:50 pm Up
s910.photobucket.com/u...k.jpg.html
try this one
paullap
PostPosted: Mon Mar 20, 2017 4:22 am Up
Ok Back to the 206, I thought I would have another look at it. I started by checking all the fuses in the BM34 under the bonnet, I was using a cheap test light , Negative part of the light to the negative battery terminal; checking for power on the fuses. All good, So then I thought I would see where there was power on the connectors. back probing with the test light. when |I got to the black connector a very thin blue wire, The test light lit up, not very bright, but there was a lot of clicking going on in the engine bay. I thought it strange, so I wedged the test light in the back of this blue wire and tried to start it, It fired up instantly. and every time until I remove the test light. when the light is not connected it wont start...
Paul
