Forums › The Car › 206 Problems › Gti 180 Oil temp gauge fault |
Posted: Mon Jan 23, 2017 10:43 am |
My oil temperature gauge works intermittently so i am assuming its a loose connection or faulty sensor .. i was wondering which sensor controls this and the location of it so i can try and fix it
thanks
Posted: Mon Jan 23, 2017 10:58 am |
It's on the sump. There's a green sensor on the back of it.
Posted: Tue Apr 18, 2017 7:12 pm |
thanks mate . its going on the ramps shortly so can have a look as having radiator sorted
