Online Now [370]:
Visitors: 369
Today: 27742
Total: 143445491
Forums › The Car › 206 Talk › disc brake thickness for 2001 206 GTI (100Kw) 2L
JimmyD
PostPosted: Mon May 29, 2017 6:39 pm Up
Hi folks,
First post here and hoping the someone can help me.
Im searching online for new brake discs for my 2001 206 GTI (100Kw, 2L) hatch and i'm finding front discs in 2 different "Heights"
...34.2mm and 27.4mm.
the other measurements seem to be the same and I'm finding both variations within each brand.
How do i know which ones i need?
Or can i use either?
Thanks in advance
PostPosted: Mon May 29, 2017 7:04 pm Up
Early GTI use 20.4 mm thickness vented discs.
Later GTI use 22 mm thickness vented discs.
There both 266mm diameter.
You need to use the correct discs & pads that match your caliper set up.
