Online Now [569]:
Visitors: 568
Today: 28049
Total: 142296549
Forums › The Car › 206 Talk › Front pads and discs
cube
PostPosted: Sat Jun 03, 2017 9:37 am Up
Morning guys,
Going to be changing the above this month, I've read the -
A) Its recommended by many people on here to get Brembo MAX discs, Ferodo Premier Pads and Ferodo Premier Shoes.
Does this mean mix makes on pads n discs ????
Looking on the Eurocarparts website, Eicher and Pagid are also available.
Anyone had any good/bad experience of the ECP ones on the 206 ???
Cheers
206 1.1 independence 54 plate, 3 door
(West Yorkshire)
PostPosted: Sat Jun 03, 2017 1:56 pm Up
Standard Brembo or Ferodo pads, discs & shoes will be fine.
PostPosted: Sat Jun 03, 2017 2:06 pm Up
I've always fitted Pagid discs and pads to our cars and they've been fine.
gazza82
PostPosted: Sat Jun 03, 2017 9:45 pm Up
Don't waste your money on Eicher ... Brembo, Ferodo or Mintex are much better.
Buy cheap, buy twice ... and not worth the risk with brakes!
PostPosted: Sun Jun 04, 2017 5:11 am Up
Also, if your thinking about upgrading the brakes, if your 206 has ABS fitted ( very possibly as 2004 was when it started to be fitted as standard ) then a set of GTI / XSI calipers will bolt straight on & allow the 266 x 22mm vented front discs to be fitted.
cube
PostPosted: Sun Jun 04, 2017 10:39 am Up
Thanks for your replies guys.
Going to get these.
www.ebay.co.uk/itm/GEN...SwImRYgmR1
(West Yorkshire)
