Latest: Puggingalong
Overall: 17129
Online Now [428]:
Visitors: 427
Today: 55014
Total: 101262171
Forums › The Car › 206 Problems › Dipped beams nor working
PostPosted: Fri May 26, 2017 3:58 pm Up
Hi all
I accidentally put on the headlights before starting the car, and both dipped beams are no longer working. I've checked and changed bulbs and the fuses are fine.
Any ideas? Did I blow something?
206 hdi 2005
PostPosted: Fri May 26, 2017 5:09 pm Up
Reboot the BSI unit.
Ive seen this bug before.
PostPosted: Fri May 26, 2017 5:39 pm Up
I did a BSI restart procedure! Still same issue!
By that you mean the standard shutdown, battery disconnect, reconnect, sidelight business right?
PostPosted: Mon May 29, 2017 7:31 am Up
Bump?
I put a multimeter on the connection and nothing!
PostPosted: Tue May 30, 2017 11:47 am Up
A faulty engine fuse box,check it correctly,if all is good,then you might have a faulty headlight stalk
PostPosted: Tue May 30, 2017 5:16 pm Up
Is there a relay or something in the stalk that would have blown?
PostPosted: Wed Jun 14, 2017 11:57 am Up
No...but have you checked the under dash fuses?
