Forums › The Car › 206 Problems › 206 central locking issues |
Posted: Sat Jun 10, 2017 8:28 am |
Hi Guys and Gals,
Battery on car went flat, recharged but now central locking aint working properly.
Can lock the car with the fob. problem is it wont unlock with the fob. can unlock each door using the key but cant do the boot as there is no key hole.
Any ideas ???
Posted: Wed Jun 14, 2017 11:05 am |
Try to do a BSI reset,and try again,that might help,if not,you need to check it using PP2000 to see if there is any fault codes stored in the BSI
