Latest: tebas93089
Overall: 17179
Online Now [104]:
Visitors: 102
Bots: 2
Today: 45645
Total: 137817377
Forums › The Car › 206 Problems › Airbag light
Airbag light
cube
PostPosted: Tue Jun 20, 2017 7:47 pm Up
Hi, does anyone in the West Yorkshire area, ideally Leeds if poss, have a code reader that works with airbag faults that i could borrow/use please ??
Or recommend a decent reader that works with airbags ??
My reader doesn't
206 1.1 independence 54 plate, 3 door
(West Yorkshire)
Sim
PostPosted: Tue Jun 20, 2017 9:24 pm Up
Your best bet is Peugeot Planet kit from ebay (PP2000, ~£55) but that needs Windows XP 32-bit (someone had success running it on a VirtualBox)
Or give a shout in our PP2000 map thread: 206info.co.uk/Forums/v...55053.html
EV (roadtripper)
Jag S(crapped)- & X-Type
GTC VXR (sold)
PostPosted: Wed Jun 21, 2017 3:34 am Up
I run Diagbox on a 32 bit version of Windows 7 - no virtual machine required Wink
RoweY
PostPosted: Wed Jun 21, 2017 3:35 pm Up
If your light is on just check the plug under your seat as its a common fault on these, hope this helps
cube
PostPosted: Wed Jun 21, 2017 3:38 pm Up
Cheers for the replies guys.
Not very computer techy but will check the unseat wires etc.
(West Yorkshire)
PostPosted: Wed Jun 21, 2017 4:59 pm Up
Both the 206 ive owned / worked on ended up with the original connectors chopped of & replaced with Super seal connectors.
I crimped & soldered the terminal pins.
cube
PostPosted: Sun Jul 02, 2017 8:41 am Up
Morning,
Well first chance to look at the wife's car today and the airbag light problem.
I've looked under both seats and there isn't any wires or plugs at all ????
Any ideas guys ??
(West Yorkshire)
PostPosted: Sun Jul 02, 2017 9:00 am Up
Only 206 equipped with seat side airbags will have airbag wiring under the front seats.
cube
PostPosted: Sun Jul 02, 2017 9:02 am Up
Definitely doesn't have side airbags Sad
Guess a plug in needed Sad
(West Yorkshire)
cube
PostPosted: Sun Jul 02, 2017 9:03 am Up
Looking on eBay at the moment re pp2000.
Ideally what am I looking for, version and price wise ???
(West Yorkshire)
PostPosted: Sun Jul 02, 2017 9:09 am Up
Peugeot Planet 2000 with a version B interface will happily read a 206.
The Lexia / Diagbox / Planet interface & leads is what your paying for, the software is all over the internet & just comes free with the interface.
Try & get a software version C interface - not important for a 206 but if you ever want to read newer PSA products & keep Diagbox up to date then version C will be required.
Try & pick a UK seller with good feedback.
cube
PostPosted: Sun Jul 02, 2017 9:57 am Up
Thanks matey
(West Yorkshire)
