Online Now [116]:
Visitors: 115
Today: 30368
Total: 106007480
Forums › The Car › 206 Problems › Morettes
Morettes
tattl001
PostPosted: Sat Jul 29, 2017 9:28 pm Up
Hey ive got morettes just wanna check though which one is the mainbeam and which is high beam. And should the mainbeam go off when high beam is on?
mtempsch
PostPosted: Sun Jul 30, 2017 6:12 am Up
On a 206 with H4 bulb headlights, only one of the filaments are on at any time (so not to overheat the bulb)
On 206s with 'crystal' headlights with dual H7 bulbs, the dipped beam remains on as the main beam comes on.
On a multiplexed 206 the behaviour can be changed by a BSI setting.
On a pre.plex 206 the behaviour is controlled by differences in the stalk. (which is plug and play once you've sourced the other type.)
On both systems you can change the behaviour using SPDT relay to add an alternate power feed to the dipped beam bulb (or cutting the stock feed if going dual->H4) as the main beam comes on.
I'd say that with morettes and their dual lights, you want the dipped to remain on along with the main.
Silvermetallic 2004 206 RC
tattl001
PostPosted: Tue Aug 01, 2017 7:27 pm Up
It's multiplex...how do you change bsi setting, peugeot plannet?
mtempsch
PostPosted: Tue Aug 01, 2017 7:44 pm Up
Yep, Planet/DiagBox (never played with either, so don't ask me exactly how/where the setting is). I think it's been mentioned on there site, so a search fpor single optics / dual optics would probably find it.
tattl001
PostPosted: Mon Aug 07, 2017 5:32 pm Up
Would this also affect what bulb is on. Currently when I have dipped beam on my high beam comes on then when I put high beam on the dipped beam comes on lol I've got someone with peugeot planet to turn on the dual optics tomorrow can this problem be rectified via bsi setting?
mtempsch
PostPosted: Mon Aug 07, 2017 6:17 pm Up
It shouldn't and I doubt the settings are that flexible.
That sounds more like you've got the wires switched over - ie the high beam wire connected to the dipped beam bulb, and dipped beam wire to high beam bulb.
tattl001
PostPosted: Mon Aug 07, 2017 9:56 pm Up
That's what I thought i'll have a play around with the wires see what happens
