Latest: Beduff1977
Overall: 17134
Online Now [516]:
Visitors: 515
Today: 204927
Total: 107606497
Forums › The Car › 206 Problems › A list of PP Codes, helpful advice needed. 2004 206CC 1.6
skyecc
PostPosted: Thu Aug 03, 2017 7:20 pm Up
Evening all,
Need some advice on the following please. For the past few months we have had an ANTIPOLLUTION FAULT due to Ageing Cat syndrome. But today SWMBO took the car out drove about 1/2mile then much stuttering and CATALYTIC CONVERTER FAULT came up on display, and I assume judging by her description the car went into a limp mode as it would not rev past 1800rpm.
Once home I plugged in the PP2000 (which takes an age to run a Global test, but that's another story), anyways here is a list of what it told me under the Engine ECU.
Then each individual code from that page :-
So is this CAT related i.e is it totally goosed now, or just a random set of faults?
As having started the car without issue before I did the codes it ran fine, I once I had read the above codes I then cleared them, and again the car sounded fine, and they did not return yet, but the ANTIPOLLUTION always returns after a run.
Thanks in advance for any help.
Cheers
Chris
heyziq
PostPosted: Fri Aug 04, 2017 1:27 am Up
Hello this is common problem on the older 1.6 in my country too, try to change to new/ working cat converter.
If you reset the problem will disappear, but once on the road the ecu will detect an error and go to limp mode again
heyziq.com
skyecc
PostPosted: Fri Aug 04, 2017 5:11 am Up
So would the consensus be that it's CAT related then?
gazza82
PostPosted: Fri Aug 04, 2017 9:44 am Up
No. It could be the coil pack starting to fail or your plugs need a change. Thos coolant temperatures look very low too so make sure the thermostat is opening and closing properly and you have new coolant (50/50 mix with de-ionised water or pre-mixed).
Give the car a good "Italian Tune-up" .. take it out and give it "beans" and get it up to temp to burn off any residues on the cat ... they don't like poodling around on short stop-start trips and need to get hot!
And .. make sure you have no exhaust leaks. We had a pretty constant game with the lambda sensors registering faults and it turned out the exhaust was parting company with the rear silencer box.
skyecc
PostPosted: Fri Aug 04, 2017 1:34 pm Up
Ok, but surely the codes relate to something more specific.
Coolant temps low as it was only started and driven 1/2 mile before problem started.
Plugs were changed under 1000 miles ago, its had an "Italian tune" when it first threw up the ANTIPOLLUTION warning a few months ago and also every time I get to drive it, and no exhaust leaks either. Sad
gazza82
PostPosted: Fri Aug 04, 2017 5:38 pm Up
The cat won't cause the misfire but the misfire will make the cat look bad. You'll be putting unburnt fuel through it and the lambda sensors.
More out why it's misfiring first or you could damage a new one if tge problem isn't cured.
skyecc
PostPosted: Fri Aug 04, 2017 6:47 pm Up
Ok thanks. This leads me to coil pack in that case then surely?
skyecc
PostPosted: Sat Aug 05, 2017 9:08 am Up
Morning.
Now I have some time, I opened up the engine cover, it appears I have a sagem coil pack, with ngk plugs, and given that these two seem a poor combination on further reading, should I get some Bosch plugs? However I cannot seem to find a recommended coil pack though, choices I've seen are Delphi, HAAS, and a no brand in GSF.
Also went out for a 10 mile thrash without incident. Confused . Com? I thought it would throw a fault again.
Any thoughts please?
skyecc
PostPosted: Thu Aug 10, 2017 5:19 am Up
Any follow up people??
skyecc
PostPosted: Mon Aug 14, 2017 7:15 pm Up
Noone anything else to add?? Sad
PostPosted: Mon Aug 14, 2017 8:38 pm Up
Delphi will be decent enough for a coil pack.
skyecc
PostPosted: Thu Aug 17, 2017 4:55 am Up
Excellent. Thank you for a response.
