Online Now [50]:
Visitors: 50
Today: 2266
Total: 104952695
Forums › The Car › 206 Problems › 1998 206 strut mount
bigwul
PostPosted: Thu Sep 07, 2017 11:34 am Up
Hiya,
Sorry for posting just after joining - but I have a really basic question hopefully - is it generally Ok to replace the bearing in the strut mount - or replace the whole thing?
Mount seems fine - but spring is 'twanging' and strut feels tight.....
Thanks......
PostPosted: Thu Sep 07, 2017 7:11 pm Up
Mount should be fine. It's the bearing that wears so that should be ok.
