Latest: lio94
Overall: 17181
Online Now [83]:
Visitors: 82
Today: 17376
Total: 140363164
Forums › The Car › 206 Problems › 206 1.4hdi starting problem intermitant
mjt73
PostPosted: Fri Sep 01, 2017 7:23 am Up
can anyone help got the above every now and then it will not start (it will turn over but imobiliser is holding off fuel )
garage has replaced crank sensor and temp sensor when it will not start .there is no faults when computer plugged in but it does go blank when it doesnt start
they have told me it could be BSI (also done factory reset ) or ECu but not sure.
one thing that was noted when you turn on ignition if temperature guage needle does not move slightly then we know it will not start
does anyone have have ideas or had similar problem
PostPosted: Mon Sep 04, 2017 8:39 pm Up
Can you hear the fuel pump prime on the first turn in the key?
southwestchap
PostPosted: Tue Sep 05, 2017 7:18 am Up
1.4hdi don't have a lift pump.
Its not letting its fuel back to the tank is it? have you tried pumped the grenade prior to trying to start the car?
PostPosted: Tue Sep 05, 2017 8:35 am Up
Or could it be the usual holes in the fuel pipe caused by vibrations on the engine.
mjt73
PostPosted: Thu Sep 07, 2017 5:37 am Up
thanks for the replies its definetely not holes in fuel pipes all been checked by garage its more an electrical problem we think
but not sure if its BSI or ECu dont want to replace one and find its the other
