Latest: Beduff1977
Overall: 17134
Online Now [694]:
Visitors: 693
Today: 118186
Total: 108053364
Forums › The Car › 206 Problems › 206 2.0 HDi stiff gear lever when warm
tiagop
PostPosted: Tue Sep 26, 2017 3:18 pm Up
Hello guys,
I'm having a problem with my beautifull 206 2.0 HDi, when the engine gets warm and I'm driving for around 20 minutes, the gear shifter becomes very stiff when moving left or right. I have no problem engaging gears, I've changed transmission fluid and the shifter has been tuned. I have no idea what to expect, I'm getting it to a mechanic soon but I just wanna be prepared if I have to change the gearbox or get it repaired Sad
PostPosted: Wed Sep 27, 2017 9:25 am Up
Has the right gearoil been put in. If its the wrong grade that can make gear changes stiff.
SAE 75W-80 is the stuff your after.
tiagop
PostPosted: Wed Sep 27, 2017 9:52 am Up
No idea since it was my mechanic that made the change, he used to work for Citroen so I think that he would put the right oil. But you never know...
cosmicdance
PostPosted: Sun Oct 01, 2017 4:53 pm Up
As it is only the left and right movement of the gear stick that is stiff I would try oiling the gear linkages with WD40 at both the gearbox and shifter sides.
You can access some of the linkages from the passenger side of the car, if you jack it up and look underneath.
The other linkages you can access by taking the air filter housing completely out and looking down both towards and away from the engine.
I used to have a Peugeot 206 and my shifter was stiff in its lateral movement until I did this which then freed it up.
Andy
Andy
