Online Now [855]:
Visitors: 854
Today: 80186
Total: 145559239
Forums › The Car › 206 Problems › COMM2000 problem with low beam light
mini1275gt
PostPosted: Mon Oct 16, 2017 6:28 pm Up
Hi from Chile,
I have a Peugeot 206 S16 (engine ew10j4 MUX) and I have problems with the low beam lights.
I think that the problem is COMM2000 unit (I see that it was fixed), I have this unit: 96477522xt
I saw in the Ebay and I don't find the unit with same code.
what happen if I will buy one of this with different code? it's plug&play?
Syntoms: the Light come off repently with any reason.
Also I think that I could change the indicator switch stalk piece of COMM2000.
thanks for help,
regards from Chile
gazza82
PostPosted: Wed Oct 18, 2017 9:11 pm Up
Pugs are quite fussy when it comes to the com2000 unit. You probably need to get one that matches.
VorTechS
PostPosted: Mon Oct 23, 2017 6:31 am Up
Staff - Vortechs
I saw some options in PP2000 for replacing the COM2000 unit from the original, whilst hunting around for other thnigs.
So you may need to re-configure the car with the replacement unit so that it knows what options are available.
