Latest: tbafonso
Overall: 17130
Online Now [349]:
Visitors: 348
Today: 3842
Total: 103589691
Forums › The Car › 206 Problems › Power Steering Hose leak
silverpug108
PostPosted: Wed Nov 15, 2017 11:30 am Up
Hi
My 206 1.6 leaks fluid from the middle of the rubber PAS hose. It is crimped at each end on to the metal pipe. If I get a new hose from Pirtek , how easy/difficult is it to crimp it on to the pipe ?
I have to destroy the hose to get it off to take to Pirtek, and will therefore be without transport.(Pirtek won't do it)
Tia
PostPosted: Wed Nov 15, 2017 2:23 pm Up
The hoses can be removed from the car. The subframe might need lowering to provide access to the steering rack.
silverpug108
PostPosted: Wed Nov 15, 2017 6:06 pm Up
Thx Edward.
The pipes run across the top just behind the rad, I was hoping just the rubber hose could be replaced but it looks as though the whole of the pipe will have to be replaced.
