Latest: Stu-mill
Overall: 17131
Online Now [46]:
Visitors: 45
Today: 77463
Total: 104886274
Forums › The Car › 206 Problems › Broken plastic engine pipe
Ray2017
PostPosted: Wed Dec 20, 2017 6:25 pm Up
Hello, Anyone know what that below pipe is called, I snapped it when trying put a pit of Electric tape around as it was cracked.
PostPosted: Wed Dec 20, 2017 8:02 pm Up
Cut the pipe off it's connectors and replace with suitable silicone hose.
Ray2017
PostPosted: Sat Dec 23, 2017 8:20 am Up
Thanks Edward, will give that a go.
PostPosted: Sat Dec 23, 2017 11:42 am Up
As long as you measure the connectors accurately you might not even need any jubilee clips to hold the new hose on.
