Online Now [72]:
Visitors: 72
Today: 1037
Total: 106046921
Forums › The Car › 206 Problems › Getting at Injectors
ChrisOfBristol
PostPosted: Tue Dec 19, 2017 10:15 pm Up
I want to check the injectors on a Peugot 206 1.6 16valve. Can't find any info on it. The rail is held on with two bolts, but there is a black plastic cylinder (presumably something to do with air intake) which completely covers the rail, so the rail can't be got at. I obviously need to remove that cylinder but I can't see any bolts/clips for it - any idea how to remove it?
2005 206cc petrol 1595cc 16 valve
josh_4000
PostPosted: Mon Dec 25, 2017 1:04 pm Up
that cylinder thing is the throttle body, you would half to remove the manifold to remove that
Best of luck
05 206 1.1 8v (mine) *sold* my first car :'(
13 208 1.2 16v Vti (dads but I'm insured on it)
-I maybe studding vehicle mechanics but this dose not mean I'm good at it Smile
ChrisOfBristol
PostPosted: Wed Dec 27, 2017 9:52 pm Up
It's the top of the inlet manifold, the metal thing with the black front is the throttle body. There are some great pictures of it here (I'll remove the link when it's sold Smile www.ebay.co.uk/itm/02-...Sw4CFYnMKm
The manifold seems to have top and bottom halves, but I can't see how they come apart - they may even be stuck together, and it wouldn't help anyway.
It looks like it might be possible to move the injector rail up a bit and out of the way, but if not it would be necessary to unbolt the manifold from behind the engine - a nightmare.
Luckily it's academic as I have found the problem and it's not the injectors. It would be good to know how to do this fairly basic thing though, and I'll post a "How-To" if someone tells me.
gazza82
PostPosted: Wed Dec 27, 2017 11:22 pm Up
207 or 307 Haynes manual will tell you .. the engine just wasn't covered in either 206 manual for some reason ...
ChrisOfBristol
PostPosted: Thu Dec 28, 2017 10:58 pm Up
Buying a manual is always the first thing to do, but I had heard that this engine wasn't covered in the Haynes manual, which is why I didn't.
Finding out that it is covered in another manual is very helpful. A good factual post by someone who has read my first one - thanks!
gazza82
PostPosted: Thu Dec 28, 2017 11:19 pm Up
Lesson 2: learn how to search this forum. All sorts of hidden gems Smile
