Latest: jackrox1992
Overall: 17186
Online Now [752]:
Visitors: 751
Today: 12936
Total: 148553670
Forums › The Car › 206 Problems › Bad earth on lights
Bad earth on lights
Dannyb010
PostPosted: Fri Dec 29, 2017 2:41 pm Up
Hi all I’m experiencing a problem with the lights on my car, I think I’ve got a bad earth as when I unlock/lock my car the side lights flash aswell as the indicators, does anyone know a solution to this
PostPosted: Fri Dec 29, 2017 3:13 pm Up
The front earth points below each front headlamp are a known problem on the 206 - simply removing the bolt, cleaning up the ring terminal & surrounding area then refitting will cure those.
The other point to check is each rear lamp cluster for water ingress - water inside the bulb holder will cause this sort of problem with the lights & electrics.
Dannyb010
PostPosted: Fri Dec 29, 2017 4:09 pm Up
Ah okay brill, I have actually just upgraded the rear lamps and they do have a little condensation in one of them, I’ll check them out and give them a clean,
Thanks a lot bud
