Online Now [62]:
Visitors: 61
Today: 61906
Total: 117525403
Forums › The Car › 206 Talk › What scanner?
What scanner?
glenpring
PostPosted: Sun Mar 04, 2018 4:38 pm Up
Hi all is there a and held scanner that would scan everything not just generic codes? I brought Lexia 3 but for the life of me couldn’t get it to work. Even the seller was unsure why it wouldn’t work as well. So just after a hand held scanner.
PostPosted: Sun Mar 04, 2018 5:18 pm Up
Did your lexia come with the correct cable?
glenpring
PostPosted: Sun Mar 04, 2018 5:31 pm Up
It looked like it. It was a copy of lexia
PostPosted: Sun Mar 04, 2018 5:53 pm Up
What wouldnt work?
glenpring
PostPosted: Sun Mar 04, 2018 6:59 pm Up
Couldn’t get the cable to connect with the car
gazza82
PostPosted: Sun Mar 04, 2018 11:22 pm Up
I have a Sealey that has Peugeot, Citroen and Renault specific compatibility ... but it may not be available now. Nothing else I tried, apart from PP2000, would give the right coded.
Check the fuse for the diagnostic port hasn't blown ... had that once on our old CC
gazza82
PostPosted: Mon Mar 05, 2018 5:20 pm Up
If you can find one it's a VS863
glenpring
PostPosted: Mon Mar 05, 2018 6:56 pm Up
Can’t find one. Can’t believe there are no hand held scanners that can check the abs and airbags and bits like that. I have a code reader for generic faults but need something that does just that bit more.
mikebrock
PostPosted: Mon Mar 05, 2018 7:52 pm Up
Hi - I use this as I got fed up using the laptop all the time. This model of scanner is for Peugeot/Citroën. Check it out on youtube.
glenpring
PostPosted: Mon Mar 05, 2018 8:27 pm Up
I was hoping I could get one that I could use on loads of cars just in case we change cars. How much that one you have and where from?
I found this one you get one brand of car for free and each brand of car after is $10 I’m hoping that’s for all the models in that brand anyone used this scanner?
Autel OBD2 Code Reader Diaglink, DIY Version of MD802 All System Diagnostic Tool for All Electronic Modules (Engine, Gearbox, ABS, Airbag, and More), EPB, Oil Service Reset www.amazon.co.uk/dp/B0...NAb4N658SE
