Forums › The Car › 206 Problems › 406 brembo brakes help |
Posted: Sun Mar 25, 2018 6:22 pm |
Hi,
Need a bit help, I’ve got some Brembo brakes from a v6 406 I’m fixing them to my 206 180. The calipers came with the brake hoses can these attach straight into the original connection, the original hoses look quite thin? If these don’t work could someone tell me what I need!
Posted: Mon Mar 26, 2018 10:52 am |
They look like normal hoses to me.
Posted: Mon Mar 26, 2018 7:03 pm |
Cheers Edward, I think I just need to give it a whirl! Might need the c5 disc as the standard 283mm might be a bit small.
Posted: Sun Jun 03, 2018 2:52 pm |
The gti 180 discs are fine there will be extra brake pedal travel and squeel with light braking I run them for years with no issues
