Latest: sparrowdclxvi
Overall: 17139
Online Now [75]:
Visitors: 74
Today: 14977
Total: 112977015
Forums › The Car › 206 Problems › 2005 206CC has no power when accelerating
pugsforlife
PostPosted: Tue May 15, 2018 5:40 am Up
the car generally drives fine but when accelerating from a standstill (esp first drive of the day) the engine loses a lot of power and you need to rev it up to get going.
our mechanic has no idea. ive run a scan, no DTCs. ive replaced the air filter, used a throttle cleaner, fuel injector cleaner, checked the plugs and now im wondering if i should try MAF sensor cleaner
so my question is a really stupid one but do these 206s have a MAF, and if so where is it? i know it should be somewhere between the air duct and the throttle - just not sure if im missing it.
its a 2.0L petrol 2005 206CC
photo below is the engine with the area i think it should be circled... any ideas on this enigma?? thanks
PostPosted: Tue May 15, 2018 5:10 pm Up
No maf sensor, it's a petrol. What happens when you put your foot down in other gears. Do the refs rise then fall back?
pugsforlife
PostPosted: Tue May 15, 2018 7:58 pm Up
ok so this model only has a map sensor then?
its really only at low speeds so issues with first, second & reverse. no major issues when driving at speed
pugsforlife
PostPosted: Tue May 15, 2018 8:24 pm Up
actually does anyone know where the map sensor is located? im thinking i might use some maf cleaner on it to see if that helps.
PostPosted: Wed May 16, 2018 3:49 am Up
Scan it with Peugeot Planet / Diagbox, i suspect it will flag the electronic fly by wire throttle body being at fault.
Generic EOBD / crappy Snap On scanners usually won't pick this fault up.
gazza82
PostPosted: Wed May 16, 2018 10:11 am Up
Usually a waste of time. If its failing, it's the electronics. I have in the past used contact cleaner (it has to evaporate leaving no residues) but this tended to just mean it fails completely quicker.
I did hear of someone who washed his .. I don't suggest trying that! Rolling Eyes
pugsforlife
PostPosted: Wed May 16, 2018 6:44 pm Up
cool, well looking at the forum seems like its a common problem. will try the maf cleaner first.
now just gotta find the stupid thing!!
