Latest: tbafonso
Overall: 17130
Online Now [411]:
Visitors: 410
Today: 43259
Total: 102619186
Forums › The Car › 206 Talk › What exhaust manifold can i use?
Rubyoptics
PostPosted: Sun Jun 17, 2018 11:14 am Up
Hey all, looking for your expertise again! Im aware that the front end of my 206 cc is basically the same as any other 206 hatchback. I know that I have additional braces running from the front end to the side sills to aid in rigidity. My question is as follows...I know that i can't use an exhaust system desgined for a hatchback as the centre pipe is different, but as i have the 2.0 EW engine, can i use an exhaust MANIFOLD that was designed for the 206 GTI in order to free up a wee bit of power?
PostPosted: Sun Jun 17, 2018 12:09 pm Up
Yes. Although aftermarket manifolds a much longer than standard ones so stiffer engine mounts are needed to reduce excess movement.
Rubyoptics
PostPosted: Sun Jun 17, 2018 12:22 pm Up
Thank you very much for the info Edward, I've read through the whole of your build thread, so if there is anyone who knows this stuff, it's you!
