Latest: Puggingalong
Overall: 17129
Online Now [329]:
Visitors: 328
Today: 28973
Total: 101723924
Forums › The Car › 206 Problems › Finding the car's spec
dlovett
PostPosted: Tue Jul 24, 2018 8:56 am Up
Can anybody help me get my car's full spec please? Peugeot haven't been much help with this. the vin is VF32E8HXF43207133.
Many thanks
VorTechS
PostPosted: Tue Jul 24, 2018 8:59 am Up
Staff - Vortechs
PRODUCT TYPE CAR
COMMERCIAL MARQUE/COMPONENT TYPE PEUGEOT
VEHICLE FAMILY 206
SILHOUETTE 5 DOOR ESTATE
TRIM LEVEL X LINE
ENGINE DV4TD TURBO DIESEL
TRANSMISSION BVM5
PAINT TYPE METALLIC PAINTWORK
BODY COLOUR EZR - PAINT ALUMINIUM GREY
INTERIOR TRIM TYPE ANDORRE PLAITED CLOTH + EFKA "PA"
UPHOLSTERY COLOUR "FU"
GEARBOX (CHARACTERISTICS) BVM MA5 / O
ENGINE (TYPE) DV TYPE ENGINE
OTHER BADGE WITHOUT FULLER BADGE
OTHER BADGE, " MISC. " SW
BADGE WITHOUT BADGE
TRIM LEVEL X LINE
STEERING UNVARIABLE POWER STEERING
SPEEDOMETER DRIVE TACHO TORQUE 21X18
FUEL FILLER CAP FUEL CAP WITHOUT LOCK
DIESEL FILTER WATER DETECTOR WITHOUT DIESEL FILTER WATER DETECTOR
CYLINDER BLOCK (MATERIAL) CRANKCASE ALUMINIUM
FUEL DIESEL FUEL
EMISSIONS STANDARD (ENGINE) EEC 2000 DEPOLL (ENGINE)
PRE-FILTER ASSEMBLY WITHOUT PRE-FILTER
CATALYTIC CONVERTER 2-COMPONENT PLATINUM FILTER CATALYSER
OIL COOLER MNTG WATER/OIL EXCHANGER ON ENGINE
OPTIMISATION OF VEHICLE’S CONSUMPTION WITHOUT FUEL CONSUMPTION OPTIMISATION
COOLING MOTOR RADIATOR TH: 27-21 DM2 THREAD 1,1 WITHOUT CLPIS IN
CRANKCASE GAS CIRCUIT HEATING W/O HEATER CASING GAS CIRCUIT
FUEL SUPPLY CUTOFF FUEL FEED CUT-OFF
RHEOSTAT RHEOSTAT
EOBD SELF-DIAGNOSIS SYSTEM WITHOUT "EOBD" AUTO-DIAGNOSTIC
DEVICE (ANTIPOLLUTION) "EGR" EXHAUST GAS RECYCLING
VEHICLE TECHNICAL DEPOLLUTION L4 VEHICLE TECHNICAL DEPOLLUTION
PARTICLE FILTER WITHOUT PARTICLE FILTER
FAN 2 TWO-SPEED 250W FANS
FUEL VAPOUR RETRIEVAL WITHOUT PETROL VAPOUR RECUPERATION
INJECTION ASSOCIATED VARIANT MOUNTING BOSCH
TANK FILTER RESERVOIR FILTER INTERIOR
THROTTLE HOUSING (ENGINE INLET AIR CIRCUIT) WITHOUT THROTTLE HOUSING (INTAKE AIR ENGINE)
TRANSMISSION BVM5
FINAL DRIVE RATIO REAR AXLE HYPOID GEARSET 17 X 64
WHEEL STYLE 14 INCHES OPTIMIZED WHEEL
GEARBOX SAFETY LOCK W/O G/BOX SECURITY LOCKING
GEARBOX TYPE (TYPE APPROVAL) GEARBOX MA/5 0
DIFFERENTIAL (GEARBOX) STD GEARBOX DIFF
TYRE (SIZE, TYPE) 175/65 R14 82T NON REINFORCED TYRE
WHEELS FITTED 5,5" RIM ROAD WHEELS
WHEEL (TYPE) STEEL WHEELS
GEARBOX TYPE MA
ABS W/O ABS BRAKES
REAR ANTI-ROLL BAR REAR ANTI-ROLL BAR DIAM 20
FRONT ANTI-ROLL BAR FRONT ANTI-ROLL BAR DIAM 22
SERVICE BRAKE WITH COMPENSATOR SLAVE
BRAKE TYPE VENTILATED FRONT DISCS/REAR DRUMS
SUSPENSION NORMAL SUSPENSION
DYNAMIC STABILITY CONTROL SYSTEM WITHOUT ELECTRONIC STABILITY PROGRAM
BRAKE ASSOCIATED VARIANT WITHOUT ABS
PEDAL BRACKET (TYPE) PEDAL STANDARD
VorTechS
PostPosted: Tue Jul 24, 2018 9:01 am Up
Staff - Vortechs
HORNS HORN STANDARD
AERIAL SHORT REAR AERIAL
FINISHER (SELF-ADHESIVE) BLACK DOOR PILLAR WITHOUT DECORATIVE PATTERNS
SIDE MOULDINGS (TYPE) DYED SIDELAMPS
SIDE MOULDINGS (DIMENSION) STANDARD LATERAL PROTECTORS
WHEEL EMBELLISHER (STYLE) FLORIDA STYLE 6 HOLES 14 INCHES
ADDITIONAL SHIELD (UNDER ENGINE) W/O ENGINE UNDERSHELDING
EXT. REARVIEW MIRROR COMP. FUNCTION EXT MIRROR MANUAL-FOLD BACK
EXHAUST TAILPIPE TRIM W/O EXHAUST OUTLET EMBELLISHER
ENGINE BAY SOUNDPROOFING BONNET+BULKHEAD+POWER TRAIN SOUNDPROOFING
WINDSCREEN WIPER FRONT WIPER BLADE W/O RAIN SENSOR
REAR SCREEN WIPER REAR SCREEN WIPER
HEADLAMP WIPER W/O HEADLAMP WIPER
FRONT PANEL BLANK WITHOUT FRONT BUMPER PLUG
ROOF GLASS WITHOUT ROOF WINDOW
BUMPER BODY COLOUR BUMPER SINCE MOD2000
MUDFLAP REAR WHEEL FRONT MUDFLAP
LUGGAGE RACK MOUNTING WITH ROOF BARS
FRONT FOGLAMP FRONT FOG LIGHTS
SPECIAL HEADLAMP (DOUBLE OPTIC) DOUBLE OPTIC LAMPS
EXTERIOR REAR VIEW MIRROR (DRIVER SIDE) DRIVER’S DOOR MIRROR ELECTRIC CONTROL
EXTERIOR REAR VIEW MIRROR (PASSENGER SIDE) PASS EXT RRVIEW MIRROR NON HEATED ELECT CNTRL
SPARE WHEEL EMERGENCY WHEEL
EXTERIOR ACCESSORIES COLOUR EXT MIRROR FR HANDLES COLOUR REAR NEUTRAL
EXT. REAR VIEW MIRROR (DRIVER SIDE RADIUS) EXT MIRROR ASPHERICAL GLASS
SUN ROOF FIXED ROOF
BUMPER TRIM DYED BUMPER STRIP
REAR WINDOW (TYPE) REAR GLASS HEATED
GLASS (APPEARANCE) TINTED
REAR QUARTER WINDOW (TYPE) FIXED REAR QTR GLASS
WINDOW (TYPE) NON ATHERMAL WINDSCREEN
ANTI-THEFT ALARM WITHOUT THEFT PROTECTION ALARM
CIGAR LIGHTER FRONT CIGAR-LIGHTER
REAR HEAD RESTRAINT REAR HEADREST ADJUSTABLE
FRONT HEAD RESTRAINT JOINTED FRONT HEADREST
REAR SEAT SEPARATE FOLD BACK BENCH SEAT
INTERIOR ALARM DOOR OPEN WARNING (INTERIOR LAMP FLASHING)
LUGGAGE COVER WITHOUT LUGGAGE COVER
REAR SEATBELT REAR 3-POINT 3 INERTIA REEL SEAT BELT
FRONT SEATBELT PYROTECHNIC SEAT BELT WITHOUT ALARM
CLIMATE (AMBIENT TEMP) TEMPERATE COUNTRIES
AIR CONDITIONING HEATER MATRIX WITH REAR HEATING
SPEED GRADUATIONS GRADUATION MPH
GRAB HANDLES FR + RR HANDLES WITH HOOKS
TACHOMETER REV COUNTER WITH NEEDLE
RADIO EQUIPMENT FEED AERIAL RECEIV FRT SPEAKER TWT REAR SPEAKER
CONSOLE CONSOLE WITH REAR HEATING
DRIVING POSITION RIGHT HAND DRIVE
REMOTE CONTROL REMOTE CONTROL ASSEMBLY
ADDITIONAL HEATING AUTOMATIC ADDITIONAL HEATING
LOAD SPACE LIGHTING WITHOUT ARRANGING LIGHTING
BOOT AND LOAD SPACE LIGHTING AUTO BOOT LIGHT OR LOAD VOL SWITCH
DASHBOARD EQUIPMENT GREY CENTRAL PANEL + BLACK DIFFUSER BUTTON
MISC. INT. LAMPS LESS INTERIOR LIGHT
INSTRUMENT PANEL (CHARACTERISTICS) GRADUATION 210 KM/H OR 135 M/H ALUMINIUM LAND
TACHOMETER (SIGNAL CONNECTION) REV COUNTER CALC
CHILD SEAT ANCHORING POINTS WITHOUT CHILD SEAT MOUNTING
LOUDSPEAKER MOUNTING 2 LS FR + 2 TWEETERS + 2 LS RR
RADIO CONTROLS REMOTE RADIO CONTROL WITHOUT CD FUNCTION
FRONT PASSENGER SEAT HEIGHT CONTROL WITHOUT FRONT PASSENGER SEAT HEIGHT ADJUSTMENT
DRIVER SEAT ADJUSTMENT DRIVERS FIXED LATERAL BEARING
FRONT PASSENGER SEAT ADJUSTMENT PASSENG FIXED LATERAL BEARING
DRIVER’S SEAT FOLDING W/O FOLDING DRIV FRONT SEATING
FRONT PASSENGER SEAT FOLDING W/O FOLDING PASS FRONT SEATING
EXTERIOR TEMP. INDICATOR EXT TEMP INDICATOR
COMPACT DISC WITHOUT COMPACT DISC
STOWAGE BIN WITHOUT SETTING BOX
SATELLITE NAVIGATION SYSTEM WITHOUT NAVIGATION SYSTEM
REAR WINDOW LIFT MAN CTRL REAR WINDOW LIFTER
DRIVER’S WINDOW LIFT ELECTR CONTROL DRIVERS FRONT WINDOW LIFTER
PASSENGER’S WINDOW LIFT ELEC CNTRL PASS FRONT WINDOW LIFTER
DISPLAY DISPLAY (CLOCK AND OR TEMP)
CLOCK NUMERIC CLOCK
OIL GAUGE STD OIL LEVEL INDICATOR
HEATING ELEMENT NON HEATED SEAT
FRONT LATERAL AIRBAG WITHOUT FRONT SIDE AIRBAG
PASSENGER AIRBAG PASSENGER AIRBAG
ON-BOARD COMPUTER NO COMPUTER
EQUIPMENT PACK W/O EQUIPMENT PACK
EXTERIOR REAR VIEW MIRROR (HEATED) HEATED DOOR MIRROR
AIRBAG DEACTIVATION MANUAL AIRBAG DEACTIVATION
INTERIOR DOOR CONTROL (APPEARANCE) NEUTRAL FINISH INSIDE DOOR HANDLE
FRONT SEAT GUARD WITHOUT CAB PROTECTION PANEL
FRONT SUN VISOR DRIV+PASS SIDE (W/O NOTICE)
RADIO RECEIVER "RD3" RDS COMPACT DISC AUDIO SYSTEM
REFRIGERATION SINGLE AIR CONDITIONING
CRUISE CONTROL WITHOUT SPEED CONTROL
DRIVER’S SEAT HEIGHT CONTROL PARALLEL DRV HEIGHT ADJ
RHEOSTAT RHEOSTAT
STORAGE (OTHERS) STORAGE COMPARTMENT FR + RR DOORS + WALLET
CARPET COVER W/O CARPETMAT
DRIVER AIRBAG DRIVERS AIR BAG
LOAD SPACE STORAGE WITH BOOT TIDY
CARPET F550 PILE CARPET
LIGHTING TIMER NOT ADJUSTABLE TIMER
SWITCH ELECTRONIC ANTI-THEFT KEY
TRIM ADAPTATION GEAR LEVER KNOB PLASTIC+CHROME INSERT
EQUALISER AMPLIFIER WITHOUT EQUALISER AMPLIFIER
LOCKING CONTROL SIMPLE CENTRAL LOCKING
STEERING WHEEL RUBBER STEERING WHEEL 3 BRANCH
STORAGE SPACE LOCKS GLOVE-BOX WITHOUT LOCKING
ALTERNATOR ALTERNATOR 150 AMP
HORNS HORN STANDARD
BATTERY BATTERY L1 300
STARTER MOTOR STARTER MOTOR CL 4
SPECIAL LIGHTING WITHOUT PARTICULAR LIGHT
MULTIPLEXING MULTIPLEXING ASSEMBLY
SPECIAL SPECIFICATION X LINE NV2
ATMOSPHERIC CONDITIONS NORMAL ATMOSPHERE
FIRST AID KIT FIRST AID KIT PACKAGING
RADIO HEADPHONE SOCKET WITH ACCESSORIES SOCKET
VorTechS
PostPosted: Tue Jul 24, 2018 9:02 am Up
Staff - Vortechs
Should be enough information in there for you. Wink
dlovett
PostPosted: Tue Jul 24, 2018 11:52 am Up
Thank you so much that's brilliant!!!!
dlovett
PostPosted: Tue Jul 24, 2018 12:24 pm Up
Looking at the list it has:
Does the headphone/accessories socket mean there actually is an aux in hidden away somewhere ?
Cheers
