Online Now [577]:
Visitors: 576
Today: 47586
Total: 105186761
Forums › The Car › Request a how-to › 1.4 16V to 1.6 16V
1.4 16V to 1.6 16V
Forum IndexRequest a how-to
Projectsport
PostPosted: Sat Sep 01, 2018 2:56 pm Reply with quote Up
Swapping out my 1.4 16v for a 1.6 16V in a few weeks. Been informed it’s a straight forward swap, anyone else done it?
RoweY
PostPosted: Tue Sep 04, 2018 6:34 pm Reply with quote Up
Yes pretty straight forward swap mate a lot of saxo's/106's do this swap.
Projectsport
PostPosted: Sat Sep 08, 2018 7:18 am Reply with quote Up
You know of any threads on it and how to’s? Does the loom need swapping is what I need to know mostly
PostPosted: Sat Sep 08, 2018 9:04 am Reply with quote Up
Doesn't the 1.4 16v have VVT? The 1.6 doesn't. I suspect there will be more to this than you think.
Projectsport
PostPosted: Mon Sep 10, 2018 10:56 am Reply with quote Up
Yes it does have VVT, far as I’m aware the looms are identica and so is the running gear, the VVT shouldn’t have any effect on it
PostPosted: Mon Sep 10, 2018 6:36 pm Reply with quote Up
But your ECU is expecting to have a VVT input but the 1.6 doesn't have one.
Projectsport
PostPosted: Sat Sep 15, 2018 12:59 pm Reply with quote Up
Aready got a 1.6 ECU, BSI, immobiliser chips etc Smile I’m more concerned about loom, mounts, box mounts etc.
Projectsport
PostPosted: Sat Sep 15, 2018 1:04 pm Reply with quote Up
So far, for what we’re aware...
ECU/BSI/chips need changing, already got.
I need to get a throttle body sensor & cable, thermostat, fluids.
Got the filters already, plus odds & sods like bolts that were lost, powerflex engine mount, etc etc
What I ideally need to know is if the 1.4 16v loom will run the 1.6 16V and if the 1.4 box will work with the 1.6
Projectsport
PostPosted: Wed Oct 24, 2018 9:28 pm Reply with quote Up
UPDATE.
2005 ET3J4 to 2006 TU5JP4.
Needed:
ECU / BSI / immobiliser chip. (NOT from a CC)
Engine loom from the TU5JP4
ALL wiring from the Ecu to fusebox to bsi down to the ABS on the rear axle.
Upper engine mount.
Posting process on my main thread. But this is totally doable!
  Quick Reply
Username:
Message:
Quote the last message
