Latest: Stu-mill
Overall: 17131
Online Now [67]:
Visitors: 66
Today: 2585
Total: 104792078
Forums › The Car › 206 Problems › What is this connector? GTi138
razza987
PostPosted: Sun Sep 09, 2018 11:44 am Up
Simple one: What is this connector? Where does it connect to?
It's been 3 years since I took the engine out and i can't remember where everything goes...
206 GTi Circuit Racer
Tricolore Trophy
www.trackattackraceclub.com
PostPosted: Sun Sep 09, 2018 3:28 pm Up
Crank sensor? Oil level sensor? Depends which part of the loom it's on. Coolant sensor is just two wires.
