Latest: tebas93089
Overall: 17179
Online Now [62]:
Visitors: 61
Today: 113547
Total: 137964398
Forums › The Car › 206 Talk › Best place to get button on wiper stalk
webbo_23
PostPosted: Thu Nov 29, 2018 1:05 pm Up
Hi all.
Just purchased a 55 plate 206 1.4hdi, but it only has the 1 line mfd. Ive read you can upgrade to the 3 line mfd. Confident with sorting that. Issue is, where is the best place to get the button for the wiper stalk? Will i have to buy the whole comms unit? Been searching on ebay for the button but no luck.
My first 206 had the 3 line display, and it would be useful to have the miles till empty and mpg etc etc
gazza82
PostPosted: Thu Nov 29, 2018 11:21 pm Up
I don't think the buttons are separate so you probably need a replacement com2000 unit ....
And PP2000 as the bsi will not be setup to handle the 3 line unit
And remember there are TWO different MFDs .. one premux, one for multiplex and they are NOT interchangable.
I swapped out the 1-line MFD on our 1.4Hdi (2002) and it works for the basic stuff (radio, doors, etc) but can't get the outside temp to work (even with PP2000) and don't have a button to try the other settings .. I can't even get the button black out to test it with a cocktail stick!
commandosqueak
PostPosted: Wed Jan 09, 2019 8:59 pm Up
It will require the whole comm unit to be changed. Quick simple job just remember to take your battery off first and follow the correct procedure.
2003 206 1.4 HDi (3 Door) LX - Cypress Green - KQM
2003 206 SW 2.0 HDI Grey
