Hi,
I've got a problem with the ABS on my (daughter's) 2007 206 1.4 Look, so I thought I'd take a quick look at the fuses. I've found the maxi-fuses, and looked at the lists of what they should be on-line (and in here, i.e. 20A Fan Unit, 60A ABS/ESP, 30A ABS/ESP, 70A BSI, 70A BSI, Blank, 30A Ignition, 20A Audio Amp), however the maxi-fiuses on this car are as show in the photo attached. As you can imagine, I'm a bit confused! Does anyone know if there were any variations of the maxi-fuses, as this seems weird.
Interestingly, there's someone else around with the same fuses, except there's no audio amp on theirs - www.nairaland.com/1003...1#39228854
