Online Now [283]:
Visitors: 282
Today: 121659
Total: 128093060
Forums › The Car › 206 Problems › 206 PAS Pump Whining - NOT!
Go to page 1, 2, 3  Next
clicon357
PostPosted: Sun Oct 06, 2019 9:52 am Up
Hello, I'm struggling to find a replacement power steering pump for the wife's 206. It's a 1.4i, petrol, non abs, year 2000. Hoping to pay around £60-75 for a recon unit.
These are the details on the pump:
PA 66-GF33
P/N 2607 9813
2606 4217
96314 11580
I've emailed a couple of eBay sellers but nobody has come back. A picture of the existing pump:
Has anyone any idea on a replacement?
Many thanks
..........I can\'t help it I just like French cars!
gazza82
PostPosted: Mon Oct 07, 2019 1:26 pm Up
www.onlinecarparts.co....58711.html
clicon357
PostPosted: Mon Oct 07, 2019 1:36 pm Up
gazza82 wrote:
https://www.onlinecarparts.co.uk/kamoka-13858711.html
Thanks very much.
gazza82
PostPosted: Mon Oct 07, 2019 1:59 pm Up
or tried these guys?
www.ebay.co.uk/usr/the...7675.l2559
clicon357
PostPosted: Mon Oct 07, 2019 3:53 pm Up
www.ebay.co.uk/usr/the...47675.l255 9
Thanks. Same place as where I went in the end. Rang the bloke, v.helpful. Fingers crossed.
www.ebay.co.uk/itm/Peu...1402235690
clicon357
PostPosted: Tue Oct 08, 2019 7:30 pm Up
Thanks all. A few quid spent now. Circa £200. Radiator, pas pump, two new drive shafts and seals. Plan to give to the lad as his first car. Bodywork is rot free is the main reason. Plus he'll be doing most of the work.
clicon357
PostPosted: Sat Oct 19, 2019 4:58 pm Up
Just an update. Replaced the pas pump today. This was done to cure a whining noise that changed pitch when you turned the steering wheel. Has made no difference whatsoever!
clicon357
PostPosted: Sat Jan 11, 2020 6:20 pm Up
Osf drive shaft today, it put up a fight but we won! Also did the wishbone as the boot was starting to split. Track rod end too whilst I was there as the hex socket on the end of the tapered bolt rounded off.
Then pullies 58 and 60. Tbh the ones I took off didn't seem too bad.
Fired her up hoping I'd cured the longstanding "whine".
Nope!
ekjdm14
PostPosted: Sat Jan 11, 2020 7:38 pm Up
Have you checked the return pipe to the pump/reservoir for cracks/splits. Even a small one in the return line that doesn't let fluid out can allow air in causing a whine. Otherwise, I'm not sure... Maybe a kink/dent in one of the hard lines could be straining the pump more than normal?
+'99 306 2.0SE cabriolet
+'97 306 1.9LXDT
French Car Forums
clicon357
PostPosted: Sat Jan 11, 2020 7:44 pm Up
Started off way back by changing the PAS pump thinking that was the cause of the noise. Changed the fluid too. Made no difference. Tonight I noted that if with the car idling on the drive I turn to full lock left or right the whine stops pretty much. Back the wheel off by even a tad and it whines again.
Would like to get to the bottom of it! Only things I haven't done are the alternator (59) and AC pulley (62). Rack maybe?
clicon357
PostPosted: Sun Jan 12, 2020 11:18 pm Up
When idling it sounds like this with an underlying whine. Rev it and the whine varies:
flic.kr/p/2ie88Vk
When idling, if you spray around the PAS pump with water which has the alternator and ac compressor below, the whine stops:
flic.kr/p/2ie86gh
As it dries out (I guess) the whine builds back up, squeals a bit then goes back to the usual constant whine:
flic.kr/p/2ie83TG
If I then turn the wheel to full lock the whine stops but as it happens there's a little squeal and a "pshhh" noise. At 13 secs in I reach full left lock and jiggle it bit on and off. Then I put it on full right lock at 27 secs in and do the same:
flic.kr/p/2iebmZE
Any ideas? I'd love to cure this noise once and for all.
ekjdm14
PostPosted: Mon Jan 13, 2020 9:10 am Up
That, to me at least, sounds like your alternator bearings are droning. Doesn't sound like a PAS whine really, it's probably just affected by the steering because the alternator is getting tight and turning the steering presents an extra load on the belt that quietens down the resonance.
The reason it stops eventually with spraying water is, I think, that the belt is effectively "aquaplaning" over the tightest pulley. I'd wager if you put a paint mark on the alternator pulley so you can see it spin easier and then did the test again you'd see the alternator slow/stop as the drone goes away. (might be a good idea to mark the other pulleys as well in case it's one of those but I really feel that's the alternator)
By the way, I'd be careful spraying water in the strut top/scuttle area there as your heater intake (pollen filter) is up under there and you could end up with wet floors and steaming up issues.
Hope this helps.
clicon357
PostPosted: Wed Jan 15, 2020 9:52 pm Up
Hope this helps.
Tried the paint trick on the alternator and PAS pullies. No sign of them slowing / stopping. However...the AC pulley, (62) appears stationary:
flic.kr/p/2ifyfgp
In this next pic you can see the AC pulley, (yes I know the belt is off). With the belt on and the engine running the AC pulley just sits and looks like this. Should the triangular plate rotate?
flic.kr/p/2ifxUiC
ekjdm14
PostPosted: Wed Jan 15, 2020 11:46 pm Up
The centre part of the AC pulley only rotates when the AC is active (even then it cuts in/out as needed) so may just be that.
If the AC works, do you notice any change in the sound when it does it's in/out routine?
+'97 306 1.9LXDT
French Car Forums
clicon357
PostPosted: Thu Jan 16, 2020 6:23 am Up
Thanks. Someone else said it should pull in and rotate when you press the AC button on the dash. It doesn't. I'll check I'm getting 12V to it for a start.
Not overly fussed having AC tbh. I wonder though if at the mo its freewheeling but on a worn bearing?
Page 1 of 3
