Online Now [1124]:
Visitors: 1123
Today: 180704
Total: 146325499
Forums › The Car › Request a how-to › Can basic clock change to MFD
nuwan
PostPosted: Sun Jul 12, 2020 7:13 am Reply with quote Up
Hi all,
Can basic clock be changed to Mfd?
This is the same what I have right now in my 206. (2006 XR with com2000)
My car VIN is VF32AKFWA44868401
gazza82
PostPosted: Mon Jul 20, 2020 7:53 am Reply with quote Up
If you swap to the correct type .. there are two. 3 and 4 bulb versions. You can't swap between the two so check your unit first.
Not everything may work as they need to be activated using PP2000. I converted my 2002 to the more complex version but have yet to get the outside temp to work even though it may have a sender in the door mirror.
nuwan
PostPosted: Mon Jul 20, 2020 1:12 pm Reply with quote Up
I think the ports are not matching. My display only having clock with one single bulb. It doesn't have the single line date and time on it. Do you think the ppt30 or ppt 40 ports are available other than the socket shown in the clock.
Appreciate your answer.
  Quick Reply
Username:
Message:
Quote the last message
