Latest: airmastertapes
Overall: 17133
Online Now [301]:
Visitors: 300
Today: 33456
Total: 106697633
Forums › The Car › 206 Problems › GTi180/RC wont go into 2nd, 4th, or reverse gear
mtempsch
PostPosted: Fri Oct 02, 2020 5:51 pm Up
As subject says, it won't go into any of the 3 "rearward" positions.
No problem with going into the " forward" positions of the gearstick, ie 1st, 3rd and 5th.
When moving stick back it's just softly springy and returns to middle position when released.
Broken cable in the linkage? Or worse,something inside the box?
Silvermetallic 2004 206 RC
gazza82
PostPosted: Fri Oct 02, 2020 6:19 pm Up
A roll-pin fell out of our linkage (that was on a 1.4 Hdi though) ...
Cheap fix though!
PostPosted: Fri Oct 02, 2020 6:32 pm Up
IIRC the GTI 180 / RC uses mechanical bowden cables to select the gears.
You need to check the cables at both ends are attached / operating correctly before condemning the gearbox.
PostPosted: Sat Oct 03, 2020 6:36 pm Up
I'd take the battery out and work out which way the linkages should be moving. Then see if they will go into gear if pushed by hand.
