Latest: Beduff1977
Overall: 17134
Online Now [642]:
Visitors: 641
Today: 102250
Total: 108734410
Forums › The Car › 206 Problems › Crankcase breather replacement
puzzledpigeon
PostPosted: Mon Apr 26, 2021 2:21 pm Up
Hey all,
I broke the crankcase breather tube on my 206, completely sheared it.
I managed to put a piece of clear tubing temporarily but the vacuum destroyed it.
Peugeot have the part but are quoting £142 for it which is ridiculous! I can't find the part anywhere, I've looked on eBay and on the internet without luck. I got a mechanic to put some more tubing there without too much luck, it's leaking and whistling.
EDIT: Just found this from amazon, is this the same?
Thanks in advance,
VorTechS
PostPosted: Wed May 05, 2021 10:31 am Up
Staff - Vortechs
Take a visit down to your local scrappy ... ?
PostPosted: Sat May 08, 2021 7:24 pm Up
Get some thicker walled silicon tubing from Ebay. Easy to find. I.e. vacuum hose.
clicon357
PostPosted: Sat May 22, 2021 6:25 am Up
Slightly different set up but the tube on the right (1.4i petrol) split. I tried taping it. First with ordinary insulating tape then amalgamating tape. The amalgamating tape was promising but failed. I then got high temperature amalgamating tape at my factors and it's been fine ever since.
..........I can\'t help it I just like French cars!
