Online Now [344]:
Visitors: 343
Today: 64708
Total: 145175017
Forums › The Car › 206 Problems › 206 GTI 180 Coil
206 GTI 180 Coil
esplace
PostPosted: Sat Jun 05, 2021 4:58 am Up
Hi,
Is anyone able to advise me of the difference between a six pin and 4 pin coil and a good brand. “Not to expensive”
I have a misfire issue especially when cold or cooled start, Rough idle and a poor fuel / air mixture smell. no warning lights.
Figure the Sparks and Coil are the best place to start but maybe someone here has a better idea
Thanks in advance
qwert
PostPosted: Sat Jun 05, 2021 11:44 am Up
If you've got NGK spare plugs in, take them out
esplace
PostPosted: Sun Jun 06, 2021 6:53 am Up
Thank you for your reply.
I’ve read reports about that, what about the Coil kit ?, I figure if the plugs are not good for the Peugeot, best that I steer clear of their coils too
Cheers
Ian
gazza82
PostPosted: Sun Jun 06, 2021 9:31 pm Up
It's more likely to be the resistors in the plugs rather than their products ...
It's a clash of Sagem and NGK plugs. I went with Bosch Super 4s in our 2.0 CC. Made it run so much smoother.
esplace
PostPosted: Mon Jun 07, 2021 5:51 am Up
Thanks Gaza,
I would usually ask for Bosch plugs, but the coil I know nothing about, haha, being an oldie that started driving with a MK 2 Zepher, I just scratch my head trying to figure out these computerized cars, like them though when they are running well
Cheers
Isn
gazza82
PostPosted: Mon Jun 07, 2021 9:30 pm Up
They can be a pain as half the time the only way you will find out the real problem is a diagnostic ... and most on the market don't work properly on the Pugs ... so a lot of people resort to the swap it and see process (which is costly when it takes several tries!).
Then there are these forums .. which usually have all the answers if you are prepared to run a few searches .. which todays facebook audience aren't prepared to do .. they want the answer now (or before they think of the question! Smile )
I learnt to drive in an Austin A35 .. and also learned the basic mechanic skills getting that car back to a legal and reliable car .. and am now rebuilding that same A35 (after over 40 years stored in my mother's garage!). Although it will definitely not be the same Wink
