Posted: Mon Jul 19, 2021 3:38 am |
I have a Peugeot 206cc. My fan kicks in around 110 degrees. Is this normal ?
Posted: Sun Aug 01, 2021 7:53 am |
Sounds normal! Should bring temp right down to 90 or below when it kicks in, if not check coolant - maybe bleed the system.
Posted: Wed Sep 22, 2021 4:27 pm |
Craig2222 wrote: |
I have a Peugeot 206cc. My fan kicks in around 110 degrees. Is this normal ? |
I don't think so.
110 deg sounds way too high for the fan to kick-in. Mine goes into 'high-speed' frenzy at that temp (happened when normal-speed fan relay packed-up).
Usually 96 degrees is the highest my temp-gauge will ever read (even on blistering hot days over here), by that time the fan has already kicked-in.
So it might be worth checking the low-speed fan relay located behind the front radiator grill.
