Online Now [483]:
Visitors: 482
Today: 155562
Total: 146610462
Forums › The Car › 206 Problems › Rear Trailing Arm Shafts
clicon357
PostPosted: Thu Aug 19, 2021 9:45 pm Up
Evening,
I've seen kits where you can buy replacement shafts to go in the end of the beam on the rear suspension:
How is the old shaft removed from the beam?
Cheers
..........I can\'t help it I just like French cars!
Mehal888
PostPosted: Fri Aug 20, 2021 6:36 am Up
With extreme difficulty.
Couple of good youtube vids.
PSA Optimal in Germany and another one from France.
The PSA/Optimal idea seems the most elegant.
They do it with the backend in situ (and have a very strong German called Hans !!!)
I have seen a quote from someone who used a sledge hammer...……
The axle/shaft in the pic above doesn't look too bad. I have seen/had far worse than that.
clicon357
PostPosted: Fri Aug 20, 2021 7:49 pm Up
Ta. Cars back together now, new bearings on the shaft pictured and seems OK.
