Latest: tbafonso
Overall: 17130
Online Now [338]:
Visitors: 337
Today: 29700
Total: 104611463
Forums › The Car › 206 Problems › Diesel fault code on Petrol 206?!
Zash
PostPosted: Sun Apr 03, 2022 2:26 am Up
Dear Gentlechaps,
Every other drive, the engine light comes on. Fault code reads:
"P2000 NOx Trap Efficiency Below Threshold Bank 1"
The problem is that my 206cc (206 GTi 2.0 16V) does not have a NOx trap - this is only really a thing on diesel cars.
Any ideas?
I am contemplating changing both O2 sensors to see if that might cure the issue...
-- Zash
gazza82
PostPosted: Sat Apr 16, 2022 8:17 pm Up
Sure that code reader works on a Pug?
I've tried a few and if it's not 100% compatible it can lead you up the garden path with a wrong code ..
Same with our old Renault .. AA said it was a "high pressure fuel pump" .. mine (Sealey and supposedly PSA compatible) said glow plug relay ... in the end it was two dead glowplugs!
