Latest: Kifi69
Overall: 17183
Online Now [446]:
Visitors: 445
Today: 79974
Total: 144900231
Forums › The Car › 206 Talk › 206 starting
206 starting
Forum Index › 206 Talk
Hanna-hdi
PostPosted: Wed Sep 14, 2022 7:55 am Up
Hi
My 1.6 16v has developed an issue starting over the last few days. On Friday morning it wouldn't start. Turn the key and all lights stayed on but no starter noise. I changed the starter Saturday which starts it's most the time but it sounds like it won't start just before it does. Then last night it was like it had a flat battery on 2 attempts but third attempt fired straight up.
I'll test the battery later as I'm wondering if the battery was starting to die?
What do you think?
PostPosted: Sat Sep 17, 2022 6:13 am Up
Start at the basics. Sounds like a low battery.
Squeakers
PostPosted: Sat Sep 17, 2022 7:16 am Up
Definitely sounds like a flat battery.
They can have just enough power to display all the lights on the dashboard but not enough to get the starter to try and turn over the engine (sometimes you just hear the starter do a single click when you turn the key with a really flat battery) The rest of the symptoms definitely sound like a almost flat battery that's just barley got the car started. Recommend charging the battery, if it still has issues, probably needs replacing.
Hanna-hdi
PostPosted: Sun Sep 25, 2022 8:17 am Up
Replaced the battery which has been fine ish for a week but now the same problem again. I had the battery and alternator checked. The alternator passed but the battery failed so that was replaced.
Now still acts like it's flat one minute but starts the next
Hanna-hdi
PostPosted: Sun Sep 25, 2022 10:38 am Up
Think I have found it. The charging rate on the battery was at 13.13v. when I tested the negative against the engine it jumped to 14.4. so I ran a new earth strap and now get 14.4 on the terminals Smile
