Online Now [441]:
Visitors: 440
Today: 6189
Total: 145116912
Forums › The Car › Solved 206 Problems › Fuel guage not working
Forum Index › Solved 206 Problems
CRUTCHIE
PostPosted: Sat May 01, 2010 12:15 am Up
Hi All,
I have a problem with the fuel guage not working on my x reg(2000) 2.0 HDi LX diesel , it just registers as full . I am looking to replace the instrument cluster , so before i start trying to unscrew things, do any of you guys know the correct part numbers for the instrument cluster , and if it has one or two plugs at the back.
appreciate any help and info .
Paul
Can i get my breather in the boot?
GazRG
PostPosted: Sat May 01, 2010 12:22 am Up
Just take the instrument cover off, it pulls towards you. Then unscrew the one screw holding the instrument cluster and the part number should be on there? You'll also see the plugs on the back.......?
'98 MGF 1.8i
Team: ex-206 owner
CRUTCHIE
PostPosted: Sat May 01, 2010 12:40 am Up
Thanks for that GazRG.
